I am going to convert VOB files to MP4 H246 and wanted to know sould I convert to MP4 or kMV?
I am going to use 1,000kbps H246
	Are you asking for a program to convert it with? You could use ripbot264, format factory, or virtualdub with a h264vfw codec installed. Xvid4psp should also work. Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	I am soory I ment sould I convert my VOB file to MKV or MP4 coded?
 I will be useing H246 so I can use a Low bit rate to get most compresson at good video
  which 'create DVD from MP4" app for Mac that takes any kind of MP4?By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 20:46
  trouble with audio after appending a .jpg turned .mp4 to another .mp4By canadianjameson in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2011, 10:55
  ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53
  loop mp4 or avi locally so will play on mp4 player - ?By marinebc11 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 21:24
  Converting to PS3 .mp4 with MP4 Converter on MacBy The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 22:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
