Hello!
I am trying to increase my knowledge about x264. On some x264 files I find information about format settings GOP in Mediainfo,
for example: Format settings, GOP : M=1, N=56
I understand the principle of GOP as described here: http://www.webopedia.com/TERM/G/GOP.html ,
and also how to set the GOP size in an x264 file.
What is this format setting and why doesn't it show on all x264 files?
Any reply greatly appreciated![]()
in x264 you use -b or --bframes to specify the number of consecutive b-frames, -I or --keyint to indicate the maximum GOP size.
Other programs you use M and N where M is the size of BP groups and N is the number of BP groups and I frames per GOP.
M=1, N=5 --> I P P P P - I P P P P
M=2, N=5 --> I BP BP BP BP - I BP BP BP BP
M=3, N=3 --> I BBP BBP - I BBP BBPLast edited by jagabo; 8th May 2011 at 08:45.
I use Format Factory to convert my Video Files to other files.
Now I no all Retail DVDs are Interlace because they are for NTSC USA TVs.
This is what I did I Decrypted my Buck Rogers DVDs and they are from the 1970's TV show.
Then I use Format Factory to convert the VOB files to MP4 and put them on my media player that has a 5. inch screen and it works good.
Now when I convert the VOB files to MP4 I have 2. option Interlace and De Interlace I set Interlace to OFF and I set De Interlace to OFF and they play great on my Media Player.
My Media Player is the Mach Speed Trio 5000 and it has an LCD screen.
And I right that LCD screen do not use Interlace and they do not use De Interlace? -
MPEG1 custom GOP settings
By sipposa in forum Video ConversionReplies: 8Last Post: 11th Jul 2011, 19:23 -
Questions about format and settings
By joeplaysguitar in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2010, 17:36 -
Convert files into a lower GOP format?
By Coroni in forum Video ConversionReplies: 3Last Post: 25th May 2010, 18:33 -
Best settings/format for short showreel
By markwhite1980 in forum Video ConversionReplies: 4Last Post: 11th Nov 2007, 21:58 -
Nero Vision 3 format Settings?
By LiBiDoXP in forum Newbie / General discussionsReplies: 1Last Post: 1st Jul 2007, 17:53
