For editing non-hd video, is a video card necessary? how many mb? does it depend which program you're using?
No. For SD video or even most HD video, the video card doesn't have much to do with editing. Some newer video cards have 'hardware acceleration' that can lower the CPU load for re-encoding, if that is part of your editing. If you don't need extensive editing, like just cut and paste editing, the video card doesn't have much of anything to do with it. Any editing that changes the framerate, the framesize, color, contrast, or most any other major changes require a re-encode. The downside is that re-encode also lowers quality.
Without a video card you can't display anything at all. How are you going to edit video? I suppose what you mean is an add on graphics card verses integrated graphics. Most IGPs are pretty weak and don't support hardware video decoding or encoding. Some of the newest IGP's do.
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 02:37 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 13:02 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48 -
Do I need a Video Card or a Capture Card...
By gnomeChomsky in forum Capturing and VCRReplies: 14Last Post: 18th Jan 2008, 21:26 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
