I have a video that is side by side, both the exact same thing. How can I either crop out one side or combine them to just have one showing?
you can use the crop filter in avidemux or virtualdub (need to add "null transform filter" in vdub)
The original video is 720p but after I cropped it the picture quality diminished. What compression would you recommend?
depends what you want to play it back on
some formats are incompatible with some devices. You've provided almost zero information on source format, destination format
you can use lossless compression or uncompressed - huge filesizes, difficult to playback
x264 is probably your best bet for quality/compression ratio ; you need the vfw version of x264 for it to show up in vdub , or you can use vdub's external encoder feature (use search there should be a guide somewhere)
lower quantizer = higher quality and higher bitrate (bigger filesizes) -
Your side-by-side very likely does NOT have 2 identical images, it's a Left- and Right-eye view of a stereoscopic image. By combining them, it would quickly become clear that they're not identical, because the horizontal disparities would show up as sections of double- or blurry-images.
Of course, cropping and then resizing is going to give you an image that is softer than a corresponding original image. But it shouldn't necessarily be "BAD". That mainly depends on what you set the encoder settings...
1280x720 cropped in 1/2 is 640x720. Even resizing back to 1280x720 won't "recreate" those missing pixels, it'll just stretch those 640 horizontal pixels out twice as wide. Quality depends alot on your expectations.
Scott -
How do I do a side by side video comparison in AvsP?
By Simcut in forum Newbie / General discussionsReplies: 15Last Post: 25th Mar 2012, 23:42 -
Video Stream Side-By-Side
By maza1967 in forum Video Streaming DownloadingReplies: 3Last Post: 10th Mar 2010, 10:31 -
Merge 2 FLV video files side by side
By zsuppguy in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2010, 16:58 -
compareing 2 videos side by side in same video. (sugestions)
By tessa101 in forum EditingReplies: 4Last Post: 9th Jan 2009, 02:36 -
Vegas 6 Side by Side Video
By CobraStrike4 in forum EditingReplies: 1Last Post: 21st May 2008, 16:23
