Hello people, I captured an hdv tape with Premiere Pro and i need to hardsub some subtitles on the movie... the file i got it's an MPeg2 1440*1080 25 frames with a bitrate of 25000... and i need the hardsubbed file to be in the same format... so i can export it to tape again with Premiere... I already try Avi Demux, Virtual dub and XviD4PSP but i cant get a fine result ( maybe because i didn't try hard enough ) but, before i loose my mind with every option of encoding in any of these programs i want to consult you people...
Which program would you use for this task?
TnX!![]()
Results 1 to 10 of 10
I don't know if Premiere Pro supports subtitles but to get back to tape you should be in a PP HDV project setting and export to tape with "Print to HDV Tape" in Premiere. I think that function was added after version CS3.
http://www.kiva.org/about -
Yeah, Premiere doesnt supports subtitles, that's why i'm looking for a program to hardsub this mpg2 file... can anyone help?
pp2 might be too old, but I think the avs import plugin should work for it for frameserving
http://videoeditorskit.sourceforge.net/
create avs script e.g. dgindex
mpeg2source("video.d2v")
textsub("subs.srt")
import the .avs into premiere into a HDV timeline and project settings. You have to interpret the file's field order (top field first), pixel aspect ratio (1.333 HDV) to match real HDV sequence 1440x1080i , then export to tape
Alternatively you can use the same script and encode a lossless intermediate for import with vdub . Same things apply with interpreting the file . The 1st method avoids big intermediate files and wasting time encoding an intermediate file -
Yeah, i got to update my premiere suite ( and all my hardware in general ) , the thing is, here in Argentina, HD editing started to kick in since last year .. and i never got the need to deal with it till now ...
Back to the topic, i understand all you say except this part :
http://avisynth.org/mediawiki/Main_Page
http://avisynth.org/mediawiki/Main_Page#New_to_AviSynth_-_start_here
1) install avisynth , put vsfilter.dll in plugins folder . Read the instructions . ssa has more formatting options than plain text srt subs
http://avisynth.org.ru/docs/english/externalfilters/vsfilter.htm
2) index your file with dgindex
3) open text in notepad in the same directory as video (or specify full path names C:\PATH ), write the code, save it, rename extension from .txt to .avs
4) open the script in vdub to preview & check that it works ok
5) import .avs into premiere -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
Signal System : 1080/50p , 1080/50i on HDC-SD700
By wisitch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 22nd Sep 2010, 08:11 -
DVD Creation Impasse 1440 by 1080 Footage
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 46Last Post: 20th Jul 2010, 10:32 -
How do I hardsub an AVI file?
By VidHunter in forum MacReplies: 17Last Post: 3rd Sep 2009, 12:34 -
1080/29.97psf with 2:2:2:4 cadence back to 1080/23.98p, how?
By metalvic20 in forum Video ConversionReplies: 0Last Post: 17th Dec 2008, 13:28
