Results 1 to 13 of 13
    May 2011
    Las vegas
    Way off topic... But HOW DO YOU MAKE A POST IN THIS FORUM?? Am I blind or is there literally no button or link to hit to make a new post thread??
    canada
    Nick12,please do not hijack threads,i moved you to your own thread where you can get more help.
  3. Member zoobie's Avatar
    Feb 2005
    Florida
    as you've probably figured out by your posting, you need to be logged in first for the post new topic button to show
    click on a forum and on the post new thread.
  5. Member DB83's Avatar
    Jul 2007
    1. Chop down tree.......
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Seriously ?
    At the top of every forum there is this nifty little button...
    Jul 2009
    Spain
    No you don't.
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Originally Posted by Noahtuck View Post
    Seriously ?
    His problem may be you don't see that button if you start at https://www.videohelp.com/ and then if you click on "Latest active forum topics" and go directly to a thread.
    You only get it if you open a subforum, like https://forum.videohelp.com/forums/25-Latest-Video-News
    May 2011
    Las vegas
    Seriously ?
    [Attachment 6740 - Click to enlarge]
    Ahh.. Thank you for pointing that out. That button doesn't show on some pages. definitely doesn't show on the index page.. Thanks again for pointing it out. I'm new to this forum.
    May 2011
    Las vegas
    Seriously ?
    Thanks Alan
  11. Member DB83's Avatar
    Jul 2007
    The arrangement where you have to select the actual sub-forum to make the new post is, I believe, usual for most forums.
    The index is just a list. 'Today's posts ' is just a list. If there was a button to make a new post on a list page the software would simply not know where to put the post.
    It is exactly the same with a reply to a topic. You can not reply until you have physically selected that topic.
    Go check other forums. If you find one where you can actually post a new topic, or reply to an existing one, before you either select the sub-forum or the actual topic then do let me know.
  12. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Where this forum is unusual is that this list is part of the default page at https://www.videohelp.com/.
    So you can navigate from this to a thread, answer it, all without seeing the top page of the forum and the subforums listed at https://forum.videohelp.com/
  13. Video Restorer lordsmurf's Avatar
    There's nothing unusual about that.
    A lot of forums are run by "code kiddies" that don't know how to setup such a basic feature.
    Baldrick is no dummy in the coding arena.
