I'm converting some YUV2 videos I've captured in VirtualDub from my tuner card into XviDs, but I'm apparently not deinterlacing correctly, because I'm getting a weird ghosting effect.
Does anyone know what settings in VirtualDub I should use to deinterlace these videos properly into 60 FPs, or 59.94 FPS, or whatever?
	What type of tuner card, unless this is hd capture the framerate will be 29.97, not 60.
	If the captured video was shot interlace 29.97 (aka 60i) then it could be bob deinterlaced to 59.94p similar to DV format. But if the source was telecined film (typical for tv series and movies) then it should be inverse telecined (IVTC) to 23.976p before encoding to xvid.
 In both cases, an alternate method is to leave it interlaced and encode to MPeg2 or h.264 interlace, then let the player deal with deinterlace or IVTC. This works particularly well for digital broadcast source.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	As a quick test try the Bob Doubler filter in VirtualDub. If you still have ghosting there are two possible problems:
 1) Your source already has ghosting
 2) Your source is interlaced YV12. VirtualDub doesn't handle interlaced YV12 properly. The colors of the two fields get blurred together.
 Post a short sample (Video -> Direct Stream Copy mode in VirtualDub) and we can tell you what the problem is.
	VirtualDub says that it's capturing as YUY2, or that's what it says when I open the compression menu. I'll get a clip up in a second.
  captured video with hauppauge card... video looks blurryBy granturissimus in forum Capturing and VCRReplies: 4Last Post: 2nd Feb 2011, 07:43
  Using S-Video To Capture Into Hauppauge 1600 TV Tuner CardBy waldodiodio in forum Capturing and VCRReplies: 4Last Post: 1st Nov 2010, 18:49
  Connecting TV Tuner Card / Sound card for best audio capture??By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13
  Best video and sound card with Hauppauge TV TunerBy nagihcim1 in forum Newbie / General discussionsReplies: 0Last Post: 28th Jul 2008, 09:57
  Quality of a DVB/Tuner card ; but simplicity of a Capture card.By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
