  1. This may seem a silly question but I have two Divx certified DVD players and today just on a lark I decided to burn my first Divx DVD. So I burned two .avi files to DVD but when I pop them in the players they see the folders but then tell me the file is not supported. I've tried Nero and a couple of other programs but no luck. Any suggestions as to what I'm doing wrong or can you point me to a good guide? I'm thinking this should be fairly straightforward.
    See https://forum.videohelp.com/threads/295067-Common-DivX-DVD-Players-AVI-Playback-problems!
    How did you create the avi? Downloaded? Easiest is to reconvert with avirecomp.
  3. Thanks for that Baldrick. This particular .avi began life as a .flv I downloaded off the internet and converted to avi in SUPER.
  4. Use GSpot to examine your file. Does it have any of the problematic features in the link Baldrick posted? I suspect your problem is the frame size. Greater than 720 wide or 576 high.
