i'd like to pad and add frame number to 2 video files for syncing purposes
i have 2 video files (2 cams , live show)
that i want to edit into scenes or shots into one continuous file keeping everything in sync
with the audio i can do it fairly easily (demux , sync , remux onto the longer file)
but with the video having a frame number would help very much
would be more mathematical and i lot less guessing
i would do it all within avisynth
i would crop the pad afterwards, ( the frame number would be into the pad)
unless their is an easier method ?
i have a rather old pc and would like to do all of this with freeware
Not sure what you're asking
You can temporarily overlay frame number
e.g. showframenumber() , or some related functions like framenumber
or you can combine it with addborders, to place the overlay in a black border
Also, in avspmod, the frame number is displayed in the info panel, you don't need any other functions -
well i think i can do it with virtualdub ..
it's just for splicing my 2 files ,
cutting the scenes and gluing it all back together into one file
well i don't know if i can really do it this way
it's just really a 2 cam edit .. with freeware !??Last edited by smartel; 6th May 2011 at 22:45.
Yeah, I don't think you're being at all clear either. If you're asking how to duplicate frames to bring the audio back in synch, you can use AviSynth's Loop command:
http://avisynth.org/mediawiki/Loop
For example, to create 5 more copies of frame 1000:
Loop(6,1000,1000)
It might be easier to add to or cut from the audio. -
ok i'll put it another way ..
i have a show filmed with 2 differents cams (2 different angles)
2 continuous files , non-stop , one 21 min and another 24 min , 2 long takes , 2 plans séquence
and i want to be able to switch from one cam (file) to another while keeping everything in sync
choosing the best shots from cam to cam , hopefully in freeware
must have some simple way to do that , sorry english is my 2nd languageLast edited by smartel; 7th May 2011 at 00:08.
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Need advice on batch editing a large number of clips
By clarkkent in forum EditingReplies: 6Last Post: 6th Apr 2009, 15:57 -
POSSIBLE? Captured 8mm Movie Frame by Frame Editing
By PLW in forum Newbie / General discussionsReplies: 15Last Post: 21st Jan 2009, 13:21 -
Using a printed list of movies and the number pad on the remote
By bwd777 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Sep 2008, 18:15 -
Suggest a video editor for frame-by-frame editing
By ontherocks in forum Newbie / General discussionsReplies: 14Last Post: 24th Apr 2008, 09:36
