Hi folks,
Can you tell me from the following Freeware Converters which one would be the BEST to use to get Good Quality conversion from RMVB to AVI ...
BTW, I am numbering them so you can refer to them easier ... but they are Not in any importance order ... so!!!
1) XMedia Recode
2) Xvid4PSP
3) WinFF
4) Format Factory
5) Freemake Video Converter
Thanks,
G!![]()
Just install Real Player. The new version features a converter that does high quality conversion to WMV. It's the best I've seen. After you're done, if you hate Real Player just uninstall it or do a system restore.
I would install Real Alternative player instead if you just want playback. It doesn't have all the problems of Real Player, like trying to take over all your video playback.
I use Any Video Converter (Pro) for RMVB conversions and it's handled about every one I have encountered. RMVB is especially hard because of the varible bitrates used. Audio sync can be a major problem.
No sound upon conversion from RMVB to DVD using WinAVI Video Converter
By kris2099 in forum Newbie / General discussionsReplies: 12Last Post: 19th Sep 2010, 17:28 -
RMVB to AVI problem
By cacovelloso in forum ffmpegX general discussionReplies: 6Last Post: 23rd May 2009, 09:53 -
rmvb to mpeg/avi
By pcb in forum Video ConversionReplies: 3Last Post: 26th Jan 2008, 07:35 -
rmvb to avi using virtualdub?
By kehn in forum Newbie / General discussionsReplies: 3Last Post: 21st Sep 2007, 10:05 -
help with rmvb to avi?
By fruitpassion in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 18:46
