I use PowerVCR II to record some TV shows while I'm gone. Problem is that when it finishes recording something, it prompts for a filename to save to. This is a problem because if I try to record 2 separate things while I'm gone, only the first one gets recorded. When I get home I still have the prompt on where to save the first thing that was recorded.
I've searched though the help files that are with the program, as well as some of the forums here. Any suggestions please!?
Thanks!
Results 1 to 1 of 1
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 06:01 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
What happened to Auto Save?
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 26th Mar 2009, 21:52 -
Authoring an auto play DVD or editing an exsisting ONE to auto play
By theewizard in forum Authoring (DVD)Replies: 22Last Post: 16th Mar 2008, 11:06
