I am not sure if this question falls under this part of the forum. I am new to the whole world of burning movies to watch on a DVD player. I would use either Vista or Windows XP computer.
How do I burn a movie file to DVD to watch on a standard DVD player?
What program should I use to do the actual burning? IMG Burn, Nero, etc...
Any suggestions? Please provide some general instructions in your suggestions.
It depends on what your "movie file" is.How do I burn a movie file to DVD to watch on a standard DVD player?
It may or may not need to be converted to suitable format and or authored.
Just being an ISO does not mean anything as an ISO is just a container and can contain anything or any type of video file. -
And, of course, it may also depend upon the player you want to use - and whether or not it allows you to play videos from data discs.
If cameras add ten pounds, why would people want to eat them? -
You might take a look at some of the 'All-In-One' DVD converters here: https://www.videohelp.com/tools/sections/all-in-one-dvd-converters
AVStoDVD is popular and should give you a standard DVD that will work on most settop DVD players and most common input formats.
Burn more than 1 movie on same DVD
By smithwigglesworth0 in forum Authoring (DVD)Replies: 20Last Post: 31st Aug 2011, 23:34 -
Help getting a movie ready for DVD burn
By therock09wbt in forum Video ConversionReplies: 7Last Post: 3rd Jan 2011, 20:03 -
burn dvd without the movie menu
By xconwing in forum Authoring (DVD)Replies: 15Last Post: 31st Mar 2010, 18:52 -
How to burn 7.1 channel DVD movie?
By coody in forum AudioReplies: 7Last Post: 9th Dec 2009, 05:07 -
how to burn more than one movie to DvD using Winavi?
By apachie in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2009, 00:40
