My blu ray player do not accept Hard drives NTFS, so i have to split mkv videos.
I tested split mkv with mkvtoolnix 4.7.0 and the blu ray told "File cannot play". I made the test checked "Disable header removal compression for audio and video .." and without check, selecting "link file" and without at splitting options, and always the same message "File cannot play".
Later I tested with mkvtoolnix 3.4.0 and i made all the combination that I mentioned above. In all combinations the first split file the same "File cannot play" but in the second split file is played perfectly, video, sound, subtitles. Someone have a similar problem? Why the first is not played and the second one does?
In mktoolnix version 3.4.0 made some test with "extra options" and cue selecting "none" for video and audio input with the same result, only the second file plays.
Results 1 to 1 of 1
What is the best way to split mkv files?
By Han Solo1 in forum Newbie / General discussionsReplies: 13Last Post: 24th Oct 2012, 22:01 -
Split a mkv container
By kyrcy in forum EditingReplies: 1Last Post: 9th Nov 2011, 16:40 -
Split *.m2ts to mkv
By Emil007 in forum Video ConversionReplies: 11Last Post: 18th May 2010, 10:18 -
Large MKV split on two DVDs
By bjb39 in forum MacReplies: 2Last Post: 1st Dec 2009, 21:01 -
How do I split .mkv file to two parts?
By dilanalex in forum EditingReplies: 1Last Post: 8th Apr 2009, 03:08
