Hi,
I've had my EzCap for a while now and have been sucessfully recording my PS3.
I recently bought a Gamecube for my new gaming channel on YouTube, and recently plugged everything in to test it out.
The gamecube plays really well on my TV, it's a decent size and the image is fairly clear.
My issue is that when I put everything up in AmCap - the video is very small in the preview, and when I full screen (or just expand) the window it all gets pixelised and difficult to see.
I've tried to change the "Output Size" but it's maximum is only like 300 pixels by something.
Any ideas? (I'm not bothered about getting amazing quality - but I want it to be viewable).
Please Help,
Thanks,
Joe
Try this:
On the 'Preview Pin' set the size you want
Then click the 'Driver' button on the 'Preview Pin' screen and set that the same
(You may have to drag the screen out then.)
And also make sure your 'Capture Pin' settings are as you want them
All accessed from the 'Video' menu
I do not have an Ezcap so these settings may not be available to you.
Hardware issues in encoding
By videobread in forum ComputerReplies: 3Last Post: 23rd Nov 2011, 09:38 -
Pixelation issues with Panasonic DMR-EZ28
By DaneClark in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Apr 2010, 14:27 -
EzCap EasyCap
By Speedy1 in forum Capturing and VCRReplies: 3Last Post: 19th Mar 2010, 16:05 -
Hardware Issues
By bevills1 in forum ComputerReplies: 3Last Post: 29th Oct 2009, 13:05 -
AMcap codes
By suefyzah in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2008, 00:37
