    Feb 2004
    Italy
    Hi,
    I have a MKV movie with the dimension 960x794, and I want to set it up with an aspect ratio of 2.35 - The MKV Merge can do this, but when I say the MKV in my LG BD590 I see it in 4:3
    If I make the MKV with AVI Demux, I can force the aspect ratio to 2.35 and the video is fine.
    This is the mediainfo report:
    Formato                          : AVC
    Formato/Informazioni             : Advanced Video Codec
    Profilo del formato              : High@L4.1
    Impostazioni del formato, CABAC  : Si
    Impostazioni del formato, ReFram : 4 fotogrammi
    Codec ID                         : V_MPEG4/ISO/AVC
    Durata                           : 1h 36min
    BitRate                          : 4 647 Kbps
    Larghezza                        : 960 pixel
    Altezza                          : 794 pixel
    AspectRatio                      : 2,35:1
    AspectRatio originale            : 1,209
    Modalità FrameRate               : Variabile
    FrameRate                        : 23,976 fps
    ColorSpace                       : YUV
    ChromaSubsampling                : 4:2:0
    BitDepth/String                  : 8 bits
    Tipo di scansione                : Progressivo
    Bit/(Pixel*Frame)                : 0.254
    Dimensione della traccia         : 3,06 GiB (74%)
    Compressore                      : x264 core 106 r1732 b20059a
    Impostazioni compressione        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=2 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4647 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    colour_primaries                 : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    transfer_characteristics         : Linear
    matrix_coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    How can I force the aspect ratio to 2:35 correctly?
    Are you reconverting with avidemux? To a 2.35 resolution size?
    I guess the LG wont read the aspect ratio correctly.
