I want to edit videos from my Pioneer DVD recorder/player on my computer. Steps:
Record videos on DVD in Video Mode, Finalised.
Load DVD files onto computer via computer DVD reader/burner.
Convert DVD files from .VOB or .IFO to .mpg or similar.
Edit in Windows Movie Maker.
Convert back to DVD files and burn a new DVD using AVS DVD Authoring.
Play the edited DVD in the Pioneer recorder/player.
When I first started doing this, I could load the DVD files onto the computer and change the .VOB extensions to .mpg. After that it was easy. The only problem was that AVS Video Authoring is very slow, and I had to leave it on overnight. Now for some reason overwriting the .VOB extensions doesn't work, and I am stuck looking for video converter programs. I have tried all of the following, and nothing works (Alphabetic Order):
AVS Video Converter: Far too slow. It took 2.5 hrs to convert 100 Mb of .IFO files to .mpg. At that rate, a full DVD with 4Gb is going to take 100 hours.
AVS Video Editor: Even slower than Converter.
ConvertVOBtoAVI: Quality of .mpg files very poor - pixilated, and no good for HD TV.
DVD Decrypter and Rejig: Both copy fast, but only do files one at a time, and there is no sound on the output .mpgs. There are separate audio files, but I don't know how to combine them with the .mpg files for editing in Windows Movie Maker.
Prism: This is the best of a bad bunch, but still too slow. 100 Mb converted in 21 mins, so 4 Gb in 14 hrs.
Smartripper: I could only get it to produce a .VOB output file, which is no use whatsover.
VideoPad: Too slow. 100 Mb converted in 50 mins, so 4 Gb in 33 hrs.
VOB2MPG: When I try to play the .mpg files, Windows Media Player says Aquiring Codec, and then it only shows a lot of wavy lines on a blue background.
VOBEdit: I couldn't find any output files from this at all. It said it has done the conversion, but no matter where I looked, I could not locate the output files
I need a quick, good quality converter from .VOB or .IFO to .mpg, .wmv, or .avi. Any suggestions for this, or any ways to get round the problems I have with the converters listed above, gratefully received.
Regards.
	Use a better dvd editor like Mpeg video wizard dvd. You wont find any super solution for windows movie maker.
	Hi,
 Thanks for the replies. I looked up Womble, and the blurb says it is an mpeg editing and authoring program. (Plus it costs $100 EEEK). I obviously wasn't clear in my query. My problem is not with mpeg editing or authoring. WMM works fine. My problem is with converting DVD files (.VOB and .VRO) to mpg or similar. As I said, VOB2MPG doesn't work for me. It produces an mpg, but Windows Media Player and WMM think it is a music file, and won't do anything with it. Also VOB2MPG won't handle .VRO files, which I get from DVDs recorded in VR mode. Prism handles .VOB and .VRO it just takes forever.
  Editing MPG versus AVI/WMVBy dt126 in forum EditingReplies: 3Last Post: 29th May 2010, 17:57
  Windows Movie Maker-Sound but no video WMV filesBy mwilliams1220 in forum EditingReplies: 2Last Post: 29th Oct 2009, 15:08
  how to i convert Video_ts files to something Windows Movie Maker can editBy debbie_g in forum Newbie / General discussionsReplies: 3Last Post: 22nd Oct 2009, 14:07
  How can I convert and burn .WMV files to DVD using WIN XP tools?By Sam-SS in forum Video ConversionReplies: 4Last Post: 16th Nov 2007, 15:09
  Convert mpg2 to mpg for Movie MakerBy Cattis in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 14:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
