Hi all. New to site and looking forward to getting educated. I use the mini dv format (canon xl-2) and am looking for a playback deck (or even camcorder) that does not cost an arm and a leg. Its a real hastle to use one of my bigger cameras as a player. Suggestions?
about the only non-used cam you could get is the canon hv40. you'd get an HD cam to boot.
miniDV decks start over a grand and wouldn't be as useful as the hv40 which if you put in cinema mode matches up rather nicely to gl-2/xl-2 output as a secondary cam.--
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 18:27 -
mini DV tape into computer
By caseyrunning in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2010, 03:42 -
Mini DV tape playback issue
By jlegrand in forum MediaReplies: 2Last Post: 15th Sep 2009, 11:30 -
bad playback mini DV tape
By izzykatz in forum Newbie / General discussionsReplies: 4Last Post: 15th Aug 2009, 15:20 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18
