In the global tab on MKVmerge theres some things in there to cut video, but i can only figure out how to cut one part of the video out at a time.
Is there anyway to cut a specific time-time out?
Like i put a video in it and i want to cut out from 03:00 - 09:50 and just keep that segment.
Does anyone know how to do that?
I suggest you make several cuts. First cut will be from the start until the 3 min mark (or whatever time you wish). MKVmerge will then create 2 files; 1 with your cut (i.e start until 3 min mark) and the other will be from 3min mark onwards. Now load the 3min mark onwards clip (i.e the 2nd file created) into mkvmerge and simply cut until your desired end time (as the start time will be the beginning of your new clip). This really doesn't take too long. I just dont think that mkvmerge can cut sections out of the middle of a mkv file???
There maybe another tool that can do this; i am not sure. But i honestly believe that mkvmerge is a very good tool with excellent results (something that other tools only 'claim'). Good luck.
AVI Videos Cutting Out
By Blade of Tyshalle in forum Newbie / General discussionsReplies: 11Last Post: 8th Feb 2012, 13:49 -
Any free softwares for cutting videos without re-encoding?
By babypotato in forum EditingReplies: 10Last Post: 17th Jul 2011, 13:05 -
Cutting videos without re-encoding?
By TYLER08027 in forum EditingReplies: 3Last Post: 18th Feb 2011, 23:14 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 09:12 -
cutting bottom off of captured videos
By ChillBill in forum EditingReplies: 5Last Post: 14th Jul 2008, 20:36
