Results 1 to 11 of 11
    May 2011
    Liverpool, United Kingdom
    Hi all
    I have a spare PC knocking around that i wanna turn it into a HTPC for just mainly using XMBC for YouTube (360p/480p) and playing bbc iplayer / itv player / 4od / DVDs and possible xvid/divx converted movies and some live tv links
    Intel celeron D 3.06GHz
    2GB DDR 3200 RAM (thats the max ram this broad will take)
    250GB IDE HDD
    80GB IDE HDD (Both 7200rpm)
    altec lansing vs3151 5.1 surround sound
    100mbits LAN speed
    cheap �1 Bluetooth Stick
    The HTPC motherboad is a MSI PM8M3-V 3.1 and supports:
    � One AGP (Accelerated Graphics Port) 8x/4X slot.
    - 32-bit AGP (66MHz) for 8x/4x mode
    What graphics card and software would you recommend me? The graphics card has got to have a s-video or a scart lead
  2. For SD material the PC might be OK, for HD material, it might be a bit under-powered.
    Does the TV you will be connecting this PC to have HDMI?
  3. Start here:
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20600007850&IsNo...=AGP%204X%2f8X
    NewEgg doesn't ship internationally but that should give you an idea what's currently available in AGP. Some of those have composite and/or s-video out. This is probably a good choice:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814129132
    If your power supply can handle it.
    May 2011
    Not that fused about HD mate Just aslong as it plays nicely with XBMC for YouTube 360/480p and some TV links in there then ill use VLC (videolan) for my divx converted movies and thats mainly what i need it for.
    But if anyone has any other software then feel free im all ears hehe
    Thanks for the link mate ya a star and i do ebay aswell
    Have any idea what good PSU this would need?
    Edited: Sorry mate i seen the system requirements (300W or greater power supply recommended)
    next question is if i stick a 500W power supply on that motherbroad would it do my harm to the HTPC or what do you recommend me putting on? is currently has a 250W at the minute.
    Just though ill let you know, I did watched a youtube video in 720p on my main pc using chromium and nothing eles (see let << for description)
    CPU @ 37%
    Now. With a intel celetron D 3.06GHz / socket LGA775
    dos the D stand for dual core?
    Cheers
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    D means dual core, but a Celeron won't be a screamer.
    http://www.kiva.org/about
  6. Member edDV's Avatar
    Mar 2004
    Your HTPC goal should be DXVA graphics card decode. The Radeon HD 3650 recommended by Jagabo can handle MPeg2, h.264 and VC1 with no CPU load when using a DXVA player (e.g. MPCHC or XMBC). Older cards would only handle MPeg2 decode. Low CPU usage will keep noise and power (heat) load minimal.
    You could also add an HD tuner for off air recording.
  7. Originally Posted by edDV View Post
    You sure about that?
    The 'D' in Pentium D processors meant 'dual'.
    I don't think it means the same thing for Celeron Ds.
    http://ark.intel.com/ProductCollection.aspx?familyId=5263
    Nov 2005
    "The Intel Celeron D processor works with the Intel 845 and 865 chipset families. The D suffix actually has no official designation, and does not indicate that these models are dual-core."
  9. Check the CPU model number (Computer -> Properties) I have a Celeron E3200 in one of my computers. It's a dual core.
  10. Member edDV's Avatar
    Mar 2004
    According to http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors
    There were several Celeron D 3.066 GHz chip families but all were single core.
    The dual core Celeron D models maxed out at 2.7 GHz.
  11. You should def look into Ebay or Freecycle for an AGP card .. I actually have an AGP card fx5200 nvidia personal cinema which is of no use to me. Shipping anything from the states will be expensive and fraught with danger, as you wont, realistically, be able to return it. Viewsonic make a media player that will do 95% of what you want, with ease (viewsonic vmp74 or 75, maplins 50 notes to u gov.)
    Give the old broad max ramming .... you dirty dog (I'm simply raising awareness of sexist and gender issues in a technical forum, fnarf,fnarf)
    The electronic components of the power part adopted a lot of Rubycons.
