If you want a wider sound stage use more (increase the volume) of the stereo track and less (decrease the volume) of the mono track. But the tradeoff is that the audio quality will get more like the bad stereo track.
Your earlier idea of subtracting the right track from the mono track to produce a new left track, and vice versa, will suffer from the same sort of problems.
Results 31 to 34 of 34
Why don't you send a small (time-aligned) clip of each? We could see what we could do...
Scott -
Here are some samples of the same piece. One is in low quality stereo and the other is higher quality mono. Interested to hear what you come up with. Thanks.
This seems reminiscent of a previous thread of yours:
https://forum.videohelp.com/threads/331315-Reverse-AnalogX-Vocal-Remover
As I said there, removing the center portion of a stereo pair produces a MONO result, so that won't help you at all here.
How to use Group Waveform Normalize in Adobe Audition 3
By Hittz in forum User guidesReplies: 6Last Post: 12th Jul 2012, 05:46 -
Least Expensive Software with Video Scopes and Waveform Monitor?
By BrainStorm69 in forum Capturing and VCRReplies: 10Last Post: 30th Mar 2010, 16:40 -
"The Waveform Cache Files Folder does not have read/write access.
By fionawhitty in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2009, 20:25 -
Autoupdate of waveform amplitude
By Premjit V.P. in forum AudioReplies: 2Last Post: 30th Apr 2008, 04:05 -
What is this on the waveform monitor?
By Wile_E in forum RestorationReplies: 1Last Post: 1st Aug 2007, 23:02
