I have a question regarding the use of AC3filter in the following workflow: Bluray -> PC (m2ts file) -> Expression Encoder 4 -> WMV.
Expression Encoder requires AC3filter in order to recognize the DTS HD audio. According to Media Info, the Bluray file in question has DTS audio with 24 bit depth. In AC3Filter settings I can set it to PCM 24bit or 16bit. In Expression Encoder I can encode to 24 or 16bit depth. Is it best to keep everything at 24, or set one or the other to 16bit? I have noticed that when converting from DTS HD to AC3 most programs output 16bit, 640kbps files so I am assuming the end product that I would want is 16bit?
Also, when importing the video file in Expression Encoder, the AC3filter has two icons pop up in the system tray. One showed a 2 channel to 5.1 conversion (PCM16 2/0 [stereo] to PCM24 3/2.1 [5.1]) and the other 5.1 to 5.1 (DTS to PCM PCM24 3/2.1 [5.1])- I currently have AC3 set to 24bit. Is there a reason a two channel conversion is popping up? My concern is that I want to make sure I am not encoding some up-sampled 2 channel stereo track to 5.1. I need to make sure I am encoding from true 5.1 to 5.1.
Yes they are. The ripped m2ts actually has 4 or 5 audio tracks so if that is the reason I am not sure why AC3filter wouldn't have a separate icon for each track? And Haali media spliter comes up just like AC3 in the system tray, but it only has one audio track selected obviously. I would think that would be the only one AC3filter has "access" to, but it doesn't seem to be the case.
How to rip Bluray encoded in VC-1 and DTS HD
By Victor D in forum Video ConversionReplies: 21Last Post: 1st Oct 2011, 13:44 -
editing dvd/bluray audio files, dts-hd and ac3
By krohm in forum EditingReplies: 7Last Post: 9th May 2010, 09:31 -
Bluray PCM to DTS conversion
By HaZZaD in forum Blu-ray RippingReplies: 3Last Post: 6th Mar 2009, 21:10 -
16bit Audio on XL1 not Loud enough!
By ozab in forum AudioReplies: 16Last Post: 13th Aug 2007, 10:33 -
16bit Audio not Clear :(
By ozab in forum Capturing and VCRReplies: 0Last Post: 31st Jul 2007, 11:51
