Hey guys,
I need suggestions for headphones that can :
1. Output decent overall sound quality.
2. Best possible external noise elimination at the price range.
3. On-ear or over the ear design...(preferably snug fit so that it helps in minimizing external noise)
4. Under $50
Reason for the need of noise cancellation :
My computer is in the living room along with the TV.The tv is on whole day.Although it is a fair distance away, I can still hear all kinds of sounds from the it. As a result i cannot really enjoy the music that i m listening to on the comp and neither can i concentrate on my work due to the irritating tv noise. I want the headphones to be capable enough to atleast get the sound down by 50%.
So should i get an active noise cancellation one or just a passive noise isolation one.?
Thank You
Results 1 to 16 of 16
Over the ear works better. But I'd recommend Sennheiser whatever type you get.
Really ? Do you understand what living room is ? If you are not interested in providing a proper response to the thread, please dont take the pains to reply.Duh. Turn the TV off.
Those aren't noise cancelling but the closed shell should give a fair attenuation of ambient noise. Something like the PXC 250 are noise cancelling and should work well for the noise from a TV in another room:
http://www.amazon.com/Sennheiser-Active-Noise-Canceling-Headphones/dp/B000089GN2/
My experience is with the higher end models which are excellent. -
How much of difference will i see with the higher end models. Can you reccommend something under $100 which will show a significant improvement over the px 250. I dont like the size of px 250. I would prefer a full size, closed Circumaural type.
i like this http://www.amazon.com/Mobile-XQS-109-3-5mm-Cancelling-Headphones/dp/B003RDZDDG/ref=sr_...4539104&sr=1-2 but not too sure if i should be getting it.
Other than this i like sennheiser hd 428 but that again has passive noise cancellation.
Looking forward to your suggestions. Thank You. -
Other than this i like sennheiser hd 428 put that again has passive noise cancellation.
I don't know anything about those but the reveiws seem to be OK. I suspect the sound quality is inferior to Sennheisers. On the other hand, many people aren't looking for accurate sound, preferring more base, or more treble, or cool sounding phase distortion.
I pointed out the Sennheiser 250 earlier because you asked for on-the-ear headphones in the first post. The circumaural 428, though not noise cancelling, may have enough noise attenuation for you. And since it's passive it doesn't need batteries. Also consider the Sennheiser HD280. Sennheiser claims "up to 32 dB attenuation" for those. Every 10 dB equates to about double the perceived volume. So at -30 dB external noises would sound about ~1/8th as loud. Of course, it's qualified with "up to". Some frequencies are attenuated less than others and you need a good seal around the ears.
http://www.amazon.com/Sennheiser-HD-280-Pro-Headphones/dp/B000065BPB/Last edited by jagabo; 5th May 2011 at 08:48.
Thanks for the reply. Sorry i was away for a few days nd couldnt reply back soon.
I think i should stick to my under $50 budget. The sennheeiser 280 pro look awesome. But its hard to beleive that passive noise cancelling headphones can attenuate external noise upto 32db, although the reviews are pretty good. I would prefer not spending too much on headphones, can you suggest me any other model with good noise attenuation under $50. I will basically shortlist 3 of them and then try them at the local mall. Whichever sounds best to me i will take that . I think i have to choose between.
1. HD 428
2. XQS 109
3. ???
if it was hd 428 vs XQS 109, which one would you choose based on better noise attenuation ?? (i am fine with some comprise on quality if the attenuation works better.) -
I don't have experience with the current low end Sennheiser models. All I can suggest is you listen to all the closed cup (for external noise attenuation) circumaural (on-ear headphones usually get uncomfortable after a while) headphones you can in your price range. If possible compare to a pair of high end Sennheisers (as your baseline for sound quality) and take some music you know very well.
Yes, I'd like to hear what you finally get and how it compared to the other choices.
you won't get much for under $50...maybe something that would satisfy a teen
you need to be able to switch headphones instantly to compare
since most retail setups don't include or want to open 6 boxes of headphones for this capability, it's pretty much a crapshootLast edited by zoobie; 11th May 2011 at 13:10.
You might also consider in-the-ear buds like these:
http://www.buy.com/prod/sennheiser-pc-300-gaming-earbuds/q/loc/111/212885717.html
$43 today.
Connecting headphones
By siluet in forum DVB / IPTVReplies: 5Last Post: 14th Jan 2011, 10:22 -
The best of the best headphones for noise canceling and listening to music?
By codered01 in forum Off topicReplies: 0Last Post: 12th Jul 2009, 22:51 -
Any Suggestions for Noise Reduction Software
By blaqlion22 in forum AudioReplies: 13Last Post: 16th Jun 2009, 08:08 -
Best Headphones
By Nitro89 in forum Off topicReplies: 26Last Post: 11th Dec 2008, 18:37 -
Is noise frequency cancelling possible this way?
By Shoyriazu in forum AudioReplies: 3Last Post: 31st Jan 2008, 07:13
