I have the Samsung Galaxy Android phone, which records HD videos into files with the .3GP file extension.
iMovie 11 imports and converts these files into .MOV files. However, the resulting .MOV file is approximately four times larger.
File sizes:
.3GP: 127.4 MB
.MOV: 484.9 MB
Why does it do this? Is there a better way?
I have dozens of 3GP files on my Mac. If I import all of them, it will take up an additional 300% of disk space, and I assume that I will still have to keep the .3GP files around, just in case iMovie 11 degraded the quality when it converted them to .MOV.
That's my next question. Does iMovie 11 degrade the quality when it converts from .3GP to .MOV?
	I don't know if I need a MOV. I don't think so. I just want to be able to use the .3GP video clips to create and edit a movie in iMovie 11, but I don't want to lose any quality.
 Are you saying that avidemux will not lose any quality when it converts the 3GP file to MP4? I assume that iMovie can then use the MP4 file? Will I have to import the MP4 file with iMovie, and will iMovie then create another file in the "iMovie Events" folder? Or, can I simply drag and drop the MP4 file into the Clips browser (and hopefully iMovie will not create another file in the "iMovie Events" folder)?
 What about VLC (VideoLAN)? Will VLC convert it to MP4 without quality loss?
  iMovie - Importing time : Does a hint exist?By iwiiiiiiiiii in forum MacReplies: 4Last Post: 21st Sep 2011, 18:31
  Importing AVI vids into iMovie after applying Vdub filters: is it possible?By quantice in forum MacReplies: 17Last Post: 4th Sep 2011, 13:48
  Importing VOB files--iMovie, Final Cut Express? New to MacBy Theresa in forum MacReplies: 14Last Post: 7th Apr 2009, 09:54
  Importing DVDs into iMovieBy vasellina in forum MacReplies: 6Last Post: 12th Nov 2008, 17:49
  importing .dv in iMovieBy sneike in forum MacReplies: 1Last Post: 27th Oct 2008, 08:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
