  1. OK, so im fairly adequate at using anyDVD HD to rip blurays to hard drive,
    Then using RipBot to convert to .MKV
    I am though having a few problems with subtitles, as ive just converted LOTR trilogy and The bourne trilogy and there are no subtitles, i know you can download .srt files and load them into films when you watch but how do you hardcode subs into the image?
    Much help would be appreciated
    You can hardcode with ripbot264. http://adubvideo.net/how-to/hardsub-blurays-ripbot
    But this is not any authoring. Moving you our blu-ray ripping/conversion section.
  3. Ok but how about hardcoding not the full subs, but just the foreign bits of a film into english?
  4. Select subtitles with 'FORCED' text in file name
  5. OK well that worked with Lord of the rings, but with other things such as bourne and saving private ryan there isnt a forced just a few different english subtitles options. I dont want to have subtitles playing throughout the film, is there any way of finding out which of these subs files is juts the non english parts?
  6. Use preview Script to see if you have correct subtitles.
  7. BDSup2Sub can extract just the forced subs from the larger subtitle stream.
