  1. I created a commercial but I'm unable to get the video footage to take up the whole screen. the program will not allow me to or I haven't found a way to stretch the footage to take up the whole screen. Everytime i go to either the left/right side or the top/bottom to stretch the footage, all sizes expand or shrink at same time. Is there a way to independently move one side or top/bottom?
    TIA
    slicebogey
    Please give more information about your source, like resolution, aspect ratio, etc. Use Mediainfo if you don't know.
  3. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Turn off the aspect ratio lock.
  4. how would i do that?
    thanks
  5. Member M Bruner's Avatar
    Oct 2008
    Does the "Scale to Frame Size" option work, or are we talking about something else?
    There are no problems - only chances to excel.
    -- Unknown
    Who would you want to stretch footage?
  7. i have like 5-6 video clips that i want to resize to full screen. you can check out the clip here: http://www.youtube.com/watch?v=f3irwbANpcI. as you can see the transition is full screen but the video isn't.
