There's been a problem that has been affecting audio reproduction on my computer, and it's getting annoying. I can't quite pinpoint what might be causing it.
It sounds as if the audio slowed down and stammered a bit to then start running again fine. I may happen on videos, with different programs, or on games.
I wonder what I can do, change or upgrade to solve it.
Any hints?
Make sure your audio drivers are up to date and check your Device Manager to see how much CPU % you are using during playback. I worked on a PC recently with a audio sync problem and it turned out to be a video decoding problem instead, so check both of them.
Well, that one seems to have been easy to solve. Just updated the Realtek driver and the problem seems to be fixed.
Will keep watching.
Thanks!
Audio distortion
By silveringking in forum AudioReplies: 0Last Post: 26th Jan 2011, 17:13 -
Audio Distortion Recording from only one TV Channel
By Pierre Sonar in forum DVD & Blu-ray RecordersReplies: 3Last Post: 24th Sep 2010, 16:29 -
AC3 audio distortion and levels.
By hardhatmac in forum Authoring (DVD)Replies: 1Last Post: 19th Mar 2010, 19:39 -
Audio Distortion with SUPER
By oller_a in forum Video ConversionReplies: 9Last Post: 24th Sep 2008, 15:21 -
Audio distortion issues.
By video_enthusiast07 in forum AudioReplies: 7Last Post: 23rd May 2008, 23:37
