My problem is with sideways judder on Blu Ray discs I have made from files captured by Arcsoft Total Media Extreme from my Hauppauge HD PVR. Althought these files play fine on my computer and on my Oppo player, they have very jerky sideways panning on 2 Sony Blu Ray Players I have tried them on. I also tried to edit these files on Mpeg Stream clip and got an error message about a bad file size and they would not load, so I used Transport Stream Pack Editor to edit them, and Ts Muxer to create BDMV & Certificate files, and IMG Burn to burn. I am running Windows 7. 4gb ram
Derek
Derek,
I experienced the same problem with my Sony player a couple of years ago. Here is the thread.
https://forum.videohelp.com/threads/314742-Success-creating-and-playing-AVCHD-discs-on-...-%28BDP-BX2%29.
Never could find a solution for the Sony, except to buy a Panasonic player. As I recall, I did find that if you author using Arcsoft's software, then it will work OK in the Sony. I'd be interested if anyone was found a solution. Good luck.
wwaag -
Just tried to edit & burn with Total Media Extreme, audio was out of sync
Hauppage HD PVR
By xX-Towrd01-Xx in forum Capturing and VCRReplies: 6Last Post: 19th Mar 2012, 16:15 -
I can't capture in 720p with my Hauppage HD PVR
By Lotus Prince in forum Capturing and VCRReplies: 27Last Post: 26th Jan 2012, 00:34 -
Hauppage HD PVR or Colossus?
By yearofthespider2k3 in forum DVB / IPTVReplies: 10Last Post: 18th Apr 2011, 20:16 -
Hauppage Windows PVR
By Trollheart in forum Media Center PC / MediaCentersReplies: 6Last Post: 21st Apr 2008, 19:25 -
Annoyance with Hauppage Soft PVR
By DB83 in forum Capturing and VCRReplies: 3Last Post: 20th Dec 2007, 11:00
