Hi guys,
I have an AVI which i cant get to work, sound is working but no video is showing.
Its the first time i have ever encoutered such as an issue hopefully someone could help.
I have the following installed:
K-Lite Codec Pack - Mega (7.1.0)
X-Video Codec (1.3.1)
AVI Codec - tells me everything in the file is supported
MediaInfo provides me with the below Video info:
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 57mn
Bit rate : 11.9 Mbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 1.298
Stream size : 9.66 GiB
Writing library : XviD 1.1.0 (UTC 2005-11-22)
Thanks for the help i have been trying to resolve this for ages
You downloaded this, right? And maybe it's corrupt or incomplete?
Anyway, you didn't tell us which player(s) you're tried. If it can be played at all, I'd try MediaPlayerClassic-Home Cinema first, followed by the VLC Player. -
yes its a downloaded complete file.
I tried:
VLCGOM
KM Player
Windows Media Player -
It's just an ordinary XviD AVI. If there wasn't anything wrong with it, it would play. 9.66GB? Cut a small sample for upload somewhere.
If it doesn't work in VLC it is either a corrupt or particular file.
Codec Toolbox RS (A tool to read/change merit of codecs and many other things) -
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
most likely corrupt i guess; and no its not an illegal movie its a freeware japanese video.
Try VirtualDub. Not that it will manage to open/play that very-weird Xvid-AVI,
but the error message (if any) might be helpful
Codec missing virtualdub
By tkitez in forum Video ConversionReplies: 25Last Post: 12th Jan 2011, 20:42 -
wmv missing codec
By uglijimus in forum Video ConversionReplies: 4Last Post: 11th Jul 2009, 01:20 -
Missing a codec?
By jnojr in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2008, 17:24 -
Codec missing
By breeze9 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2008, 21:08 -
Missing Codec
By arileysr2 in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 13:13
