  1. Hi guys heres my question.
    I have a 1080p video clip, now i what i want to know is, is there a program i can use which will allow me to edit the video so i can add another video clip to the start of the 1080p video clip.
    Now i know i could use Windows movie maker but the problem with that is the file size is huge and also it only goes into wmv format which is not what i want, so is there a program i can use that will allow to put 1 video clip at the start of another video clip?
    Thanks in advance guys your great
    Feb 2008
    Twin Peaks
    What you are looking for is an HD timeline editor. Try the demo for Sony Movie Studio HD.
  3. Member olyteddy's Avatar
    Dec 2005
    For simple cut and paste editing AVIDeMux is pretty good. No encoding if the video(s) are compatible.
