  1. I have struggled for a week attempting to download some flash audio from a website.
    It seems to be a .SWF that I see when I do page source, but, I cannot figure out how to get this file to my computer....
    When I right click the SWF file there are no options for saving the file, only saving the link. I've tried flash downloaders with no success.
    Here is the link
    http://cache.reverbnation.com/widgets/swf/18/facebook_widget.swf?id=artist_353023&deep...=audio.8344909
    Can this be captured or downloaded? Optimally I would like to have as an MP3 file, but any format will do as long as I can get it.
    thanks
  2. These are progressive downloads - they are automatically downloaded to your browser's temporary internet files directory if you let it finish (the grey seek bar finishes to the end)
    It will have an .ocx extension, just rename it to .mp3
  3. Still having a problem...I do not see any files named .oxc in temp internet file folder...I checked Chrome and Firefox temp cache and this is what I see
    Please advise.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    another option is to do realtime audio recording. Use something like audacity and record to a file while it is playing. Just make sure you don't click on other stuff while recording if you have sound effects on your actions like opening windows and stuff. It will be the "what u hear" option to record if you use windows - which by the look of your screenshot I assume you do.
  5. Hey folks, finally got it to work....used GoFlash in conjunction with Firefox and that did the trick...thats for the help..
