Results 1 to 9 of 9
  1. I got 5 files appended in vdub, and i have addes one wav file for audio, only the first appended section of the 5 files now have audio, the rest is silent.
    could anyone figure it out?
  2. is the audio the same length? as the appended video files?
    if not , join the audio first, then add the new audio
  3. thanx for very fast reply!
    How do i join the audio?
  4. use an audio editor e.g. audacity
  5. Can you give me some usefull advice?
    what are trying to say?
    the audio is to short and that is the problem?
    Please explain now!!!
  6. I'm guessing that's whats going on
    The information you've provided is VAGUE
    If you want more help be more DESCRIPTIVE
    Explain what you're trying to do in more detail.
    What kind of video, audio, are they separate ?
  7. Im trying to add a audio file to 5 appended video segments. the audio is in wav format.
    Im only getting sound in the first segment of the five, the other 4 segments are silent.
    the wav file is longer than the 5 appended video files.
    what more do you want to know?
  8. are the videos the same format, fps, dimensions etc...?
    trim the audio to match the length
    in vdub, replace the audio by using audio=>audio from other file
    or use an editor like vegas or premiere
  9. Now it worked, Big thanx man!
