I am trying to de/remux the Lord of the Ring SVCDs so I can play it on my friend's Panaonic RV31 DVD player.. Since the player requires SVCD to have a VCD header..
So I copied all 4 disc's mpeg2 file onto my hard dirve.. But every time I try to load any of the file into TMPGEnc for remux, it will give me the error of "invalid MPEG stream".. Just wondering why is it giving me that error?? I tried to use BBMPEG as well, but it gives me the same kind of error.. I don't think the Mpeg 2 file is corrupt since it plays fine on my hollywood plus card on my computer and on my apex dvd player..
I am running WinXP, Athlon 1.4, 256DDR ram.. any help will be appriciated thanks..
OK, the files will work with DVD2avi, so I ued it to get the audio file out, but I still can't use either BBM or TMPGEnc to de-multiplex it to seperate the video file since it still won't let me load the file.. any idea??
You don't have to load the MPEG file into the "main" encoder window in order to REMUX.
Load TMPGenc, leave the main window along, and just goto MPEG tools.
You'll need to DEMUX and then reMUX.
Problems loading...
By alintatoc in forum ComputerReplies: 2Last Post: 9th Dec 2010, 01:49 -
SOLVED : Problems loading certain .srt subtitles
By trotskyicepick in forum SubtitleReplies: 1Last Post: 13th Sep 2010, 11:00 -
problems with avc to mpeg-2 in tmpgenc xpress 4.0 - more than 3x run time?
By NoFace in forum Video ConversionReplies: 3Last Post: 18th May 2008, 21:01 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46 -
Problem loading AC-3 audio (inside MPEG) in Premiere
By irving in forum EditingReplies: 2Last Post: 23rd May 2007, 09:25
