Does anyone know how I can link to a web site using DVD Lab Pro 2?
This is the only dvd authoring software I own. I need to make a menu that will have buttons that will link to web pages.
Thanks upfront.
Upfront, I do not think that is possible since a dvd menu must link to a property(vts) on a dvd disk.
Just think about it. You put that disk in a standard player and someone clicks the link. The player will not have a clue of what to do - no browser support. Same goes for a PC-based player.
The way you do this is to place an additional html file on the disk with the links you need. When the disk is in a PC the PC can play that file and go wherever you want it. -
Maestro, I believe?
Yep. DVD Studio Pro (Mac) used to have this function, and may still do. Also the old SpruceUp could do it.
The one I was thinking of was eDVD, which required that you install it's own player on any PC that was to be used (can't recall if it was the interactual player or just something equally crappy)Read my blog here.
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 18:19 -
DVD Lab Pro
By matthewjohn23 in forum Authoring (DVD)Replies: 5Last Post: 20th Mar 2009, 13:35 -
[DVD-lab Pro]Links dissapear/ cell linking
By Ninerian in forum Authoring (DVD)Replies: 3Last Post: 24th Oct 2008, 08:11 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 08:53 -
Help with DVD-lab pro
By Jack the Ripper in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 08:21
