I would like to stream live video on Ustream from inside a chickadee nest box that is mounted on the deck of my house. I have a Samsung laptop with Windows 7 and high speed Internet Service. What would be the best camera to use in this outdoor situation? Inside the box would be low light and would need close up to within about four to six inches. Any suggestions on the best way to do this?
The low light in the box will be a major problem. Professionals that do bird box vids usually remove one side of the box and replace it with glass. That way you get enough light to capture the babies being fed by the parents.
How to test which streaming protocols a Media Player box support?
By Eddie2010 in forum Video Streaming DownloadingReplies: 0Last Post: 16th Mar 2011, 07:29 -
live video streaming to set box Help
By alexandros27 in forum Video Streaming DownloadingReplies: 0Last Post: 9th Feb 2011, 03:28 -
Playing smooth streaming fragmented mp4 without trex box
By adammw in forum Software PlayingReplies: 0Last Post: 29th Jul 2010, 03:01 -
Realtime video generation and streaming to a set-top-box
By appel in forum Video ConversionReplies: 1Last Post: 22nd Oct 2009, 14:28 -
How to add permanent subs inside a semi-transparent box?
By majin_buu in forum SubtitleReplies: 5Last Post: 9th May 2009, 12:43
