Hi !
I've got this .mov file I want to convert to mp4 using FFmpeg.
Here are the errors and unusual messages I get everytime in the output :
Code:[mov,mp4,m4a,3gp,3g2,mj2 @ 017efb80] multiple edit list entries, a/v desync might occur, patch welcomeAnde once, I had this error message (but couldn't get it again afterwards) :Code:final ratefactor: 47.40
Any idea what this might mean ?Code:Out of memory in do_audio_out
Here's the MediaInfo of the input file, if it can help :
So if anyone has any clue what the error might be, where it might come from and how to at least circumvent it ?Code:General Complete name : C:\Users\KGagnon\Desktop\Video Test\8320_02.mov Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 4.85 GiB Duration : 26mn 10s Overall bit rate : 26.5 Mbps Encoded date : UTC 2011-04-19 19:22:31 Tagged date : UTC 2011-04-19 19:47:30 Writing library : Apple QuickTime 7.6.4 com.apple.quicktime.player.movie : (Binary) Video ID : 1 Format : hdv2 Codec ID : hdv2 Duration : 26mn 10s Bit rate mode : Variable Bit rate : 25.0 Mbps Width : 1 416 pixels Original width : 1 440 pixels Height : 1 062 pixels Original height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Bits/(Pixel*Frame) : 0.555 Stream size : 4.57 GiB (94%) Language : English Encoded date : UTC 2011-04-19 19:10:11 Tagged date : UTC 2011-04-19 19:47:30 Audio ID : 2 Format : PCM Format settings, Endianness : Big Format settings, Sign : Signed Codec ID : twos Duration : 26mn 9s Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 287 MiB (6%) Language : English Encoded date : UTC 2011-04-19 19:10:11 Tagged date : UTC 2011-04-19 19:47:30 Menu ID : 3 Language : English Encoded date : UTC 2011-04-19 19:10:11 Tagged date : UTC 2011-04-19 19:47:30
Thanks !!!
Results 1 to 1 of 1
Cannot encode .mov file to dvd using ffmpeg
By RL in forum ffmpegX general discussionReplies: 3Last Post: 25th Oct 2011, 15:43 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
Encoding .DV problems with ffmpeg (e.g. MPEG4 -> DV or VOB -> DV)
By AlphaMonk in forum ffmpegX general discussionReplies: 1Last Post: 23rd Feb 2010, 05:24 -
Problem converting mov to flv with ffmpeg
By zigune in forum Video ConversionReplies: 8Last Post: 15th Jul 2009, 03:03 -
Need a little help here (wmv/mov to flv with ffmpeg)
By yeauxyo in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 00:08
