Sorry I'm quiet new in this business
My DVD Player supports XSVCD and I heard that the quality is better than from SVCD.
My question is now : which Software can I use to create a XSVCD ?
Thx for any help !
Cheers
Degdus
http://www.vcdhelp.com/xvcd.htm
http://www.vcdhelp.com/convert.htm
http://www.vcdhelp.com/burnmpg.htm
You can use any encoder and almost any burn software.
XSVCD means only off-standard SVCD. Quality may be better or not, it depends on the source and the conversion procedure.
How to do they Create Motion in this example
By Thread7 in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2012, 15:17 -
Best way to create HD files ?
By pmugghc in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2010, 20:28 -
How to create photomation?!?
By dabigwu in forum EditingReplies: 3Last Post: 2nd Mar 2010, 21:52 -
How to create a bitstream?
By krao in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2009, 17:16 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36
