I have an 8GB TS file for a soccer game. I can't transfer it to my portable HD because the drive is formatted FAT (if I remember correctly) so I can transfer files on a Mac or PC (although I almost always work on a Mac sometimes I need to use the drive at work on a PC). I have Split and Concat but the program won't split into 2 4GB files, giving me an error message that the output size is too large. When I import into MPEGStreamclip, I see the straight line in the middle of the screen that one sees when the Quicktime component is not installed (which isn't the case).
Is there a way to split the TS file into 2 so I can transfer it to my portable HD?
Is there a way to split the file so each part will be viewable on its own with a media player (AC Ryan in this case)? And can I do that without re-encoding this file (i.e., lowering the overall quality)?
	Try tsmuxer, under split can you split by size.
 https://www.videohelp.com/download/tsMuxeR_1.10.6.dmg
	Thanks for the reply. There is actually an updated version that works with Snow Leopard, but folks need to read the Read Me text file about removing some fonts.
 I have a question about this program. It split my file into 4GB sizes, which is great, but when I open any file except the first part with VLC, the first part opens as well. Is there something I should do in the settings or preferences so each part is read as its own new part? That is, I don't want to split strictly for the purposes of transfer, although that is the most important thing, but basically to have each part be its own free-standing TS file. Thanks.
	Are you using MPEPStreamclip on a PC or MAC? If it is the PC you can get Quicktime Alternative version 1.81 (only) as freeware. On the MAC you need to buy the MPEG2 plugin from Apple - I think it is about US$18. If you don't need to actually see where you are splitting then MPEGStreamclip will actually do that without the plugin so I read on another forum, but I haven't tried that myself. SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
	I'm working with a MAC. I have the quicktime plug-in and MPEGStreamclip works fine for other uses (other than some problems posted in another thread about data breaks). But MPEGStreamclip isn't working with the TS files I have. TSMuxer worked, but as I wrote above, there are some problems post split.
  Splitting TS-file with tsMuxer creates lag in end fileBy Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 17:44
  Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16
  How Do I Split screen Half Rolling Credits-Half Video in VegasBy Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35
  Half the disk is formatted PAL, the other half NTSC...Doable or not???By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 09:31
  Uploaded video cut in half only top half showsBy MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
