Subject line says it all. I'm just curious. The current version works great, but this program has a lot of unfulfilled potential, and I'd like to see it grow.
Rats. I knew it. Anybody know of a more fleshed-out alternative? It'd be nice to see support for cutting at non-keyframes, wider support for variations in the .*TS* format (it can't splice my .MTS files from a Canon camcorder, for example), and a few other things. I'm thrilled with TSSniper as it is, but it'd be nice to see what else is out there.
I sympathize, but tsSniper is just about the only free choice at the moment (i.e. it actually works). And some of the payware alternatives aren't much better.
Yeah, I'd like to see something with advert detection, frame-accurate editing, with only cuts being re-encoded. No freeware like that exists at the moment.Pull! Bang! Darn! -
VideoReDo TVSuite H.264 Also does Mpeg, You can download and run in trial mode free. http://www.videoredo.com/en/index.htm Plus you can request a trial key to remove the 30 minute output time limitations for a period of time. That way you can see if it meets your needs. It is what I switched to.
If I'd known I was going to live this long, I'd have taken better care of myself.
TSSniper - Filtergraph error
By MACKerMD in forum EditingReplies: 24Last Post: 21st Jan 2014, 13:43 -
Is ffmpegX still in development?
By reviltihco in forum ffmpegX general discussionReplies: 5Last Post: 13th Aug 2010, 10:54 -
TSSniper - Just how do I use it to split up files?
By Asterra in forum EditingReplies: 1Last Post: 11th May 2010, 10:24 -
My gratitude for development
By plasmacutter in forum ffmpegX general discussionReplies: 0Last Post: 1st Jan 2008, 06:30 -
Still under development?
By honest_geezer in forum SVCD2DVD & VOB2MPGReplies: 75Last Post: 26th May 2007, 02:34
