I edited an avi movie with avidemux. The only way I could edit the movie is if I chose the option to Index the movie which I did. I then proceeded to edit out the parts of the movie I did not want.
The result was that the sound of the movie came out all distorted. I noticed that the frame rate
in avidemux was set at 25 frames per second while the movie itself in VLC video player showed it was set at 50 frames per second. So I used the custom setting to changed it to 50 frames per second. That didn't help. How can I edit a movie in avidemux and not get out of synch fast speed distorted sound.
I have the same problem with avidemux 2.5.4 (latest) with the very first video I tried to convert to Xvid/mp3.
It was a WMV. Then I tried an mp4, but this gives the same problem.
You already hear the audio distortion after you open the video in avidemux and play it there.
In VLC the audio is fine. Perhaps it's a bug?
Avidemux .. editing AVI h264
By rogerer in forum EditingReplies: 2Last Post: 3rd Nov 2011, 11:43 -
Sound delay issue after MPEG2 editing (avidemux)
By dodoecchi in forum Video ConversionReplies: 8Last Post: 22nd Mar 2009, 05:55 -
My .avi files have sound, but no picture with Quicktime, and are distorted.
By SyracuseMug in forum MacReplies: 3Last Post: 15th Dec 2008, 23:11 -
Joined 3 AVI Videos using Avidemux, but 1 video has sound, other 2 don't??
By UmmAddan in forum EditingReplies: 2Last Post: 31st Dec 2007, 18:04 -
How to go over bits of a movie... editing sound
By UmmAddan in forum EditingReplies: 2Last Post: 22nd May 2007, 18:58
