Hi all, I’m very new to video encoding so I am looking from some pointers to get me going on a new conversion. I have used VirtualDub in the past to edit videos and convert them to xvid which was easy enough.
This time I have what I think is an uncompressed video file (UYVY (packed 4:2:2)) with PCM audio, it is about 110GB in size, and I want to convert it to a DVD. The video file is a VCR rip so quality is not that great. I’m thinking of using VirtualDub to clean up the video but don’t really know what to do after that.
Current video size is 720 x 576 25fps and I think it is interlaced. I’d prefer to use free software since I only have 1 file to do. Any help would be greatly appreciated.
	If you choose to use VirtualDub for 'clean up', you should be aware that VD can 'frameserve' video out directly to a MPEG encoder. That eliminates a 'in-between' output file, which would be another 110GB if you kept the same format. Frameserving is one good option. Leave it interlaced. HC Encoder and QuEnc are two freeware MPEG-2 encoders.
 For a DVD, the MPEG needs to meet the DVD specifications. Several MPEG encoders out there. Since you are in PAL country, you would likely convert it to PAL DVD specs. If you look to the upper left on this page, you will see the DVD specifications, format and structure under 'WHAT IS' DVD.
 Then you need a DVD authoring program to put the MPEG-2 into the DVD format. GUI for dvdauthor is a good choice.
 Finally, burn it to DVD with ImgBurn, using good quality DVD media. Verbatim is one choice. Taiyo Yuden is another.
 All these programs are freeware. There are some 'all-in-one' programs that may do this whole conversion also. Depends on what you want to learn and what quality you want to preserve.
 And welcome to our forums.
  Convert Webcam Video for TV - uncompressed avi > asf > mov - best solution?By nakedgun in forum Video ConversionReplies: 0Last Post: 17th Nov 2011, 06:41
  Tool to convert SWF (actionscript) to uncompressed AVI or image sequence?By Koppel in forum Video ConversionReplies: 5Last Post: 1st Jul 2011, 14:23
  Exporting from uncompressed AVI to uncompressed MOVBy courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20
  Original AVI uncompressed to DVDBy santolina in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2010, 22:10
  Uncompressed 24bits RGB AVI - how to convertBy mooplesdooples in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 22:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
