Does anyone know of a program that would get a signal from firewire or a video capture card and record it straight to DVD with out the need to re-render the video.... for Mac.
I found a program called 'Instant DVD Recorder' from Pinnacle which is perfect but it is for Windows. I have a MacBook Pro
Results 1 to 12 of 12
Thread moved to the mac forum where you can get advanced help.
You would do better with a stand alone DVD recorder.
Computer direct DVDR recording has always been unreliable. Firewire to DVD would require real time software MPeg2 encoding. The Mac has never supported this well. Mainconcept has the best real time MPeg2 software encoder.
http://www.mainconcept.com/products/sdks/video/mpeg-12.htmlLast edited by edDV; 28th Apr 2011 at 19:36.
http://www.kiva.org/about -
I've been doing test recording straight to DVD on with XP (bootcamp) but my system has frozen several times. I might be off better just recording to HDD in windows and the re-start on MAC and then burn the VIDEO_TS folder using toast. I'm impressed with this 'Instant DVD Recorder' it is doing a good job but disappointed that I have not found anything like that for mac.
The El Gato Hybrid USB dongle captures in MPEG2 but wraps it in a proprietary container. However, once the recording is done, you may export it as TS (which take only a minute or two as it's maintaining the format but simply exporting it out of the proprietary container). Then you drop it on Toast and it's ready to author/burn (with no re-encoding necessary). I have one; it works.
But if you're looking for 10 minutes max, it might not be possible as it does take a certain amount of time to actually burn the disc, eh? -
Record DSLR footage straight to my Mac
By Mac_Newbie in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 4th Dec 2011, 00:29 -
Use DVD Fab to capture audio commentary rather than straight film dialog
By loninappleton in forum Newbie / General discussionsReplies: 12Last Post: 20th Aug 2011, 12:26 -
Video capture straight to temporary storage?
By travail in forum Capturing and VCRReplies: 6Last Post: 2nd Jul 2011, 20:20 -
Switching to capture on Mac, however what happened to the video metadata?
By ArthurDaley in forum Capturing and VCRReplies: 2Last Post: 23rd May 2010, 05:31 -
Video Capture on Mac
By jonlesterwhite in forum MacReplies: 4Last Post: 29th Nov 2009, 05:41
