I don't understand this program because I've got to be doing something wrong! After finally getting my flv video files to convert to mp3, they don't work! Will not play, burned to cd and don't play, Quicktime does not recognize and they will not transfer to Itunes. I see that the files have the extension of flv.ff.mp3.
HeLp!!
I don't get the moving me part because it looks like this IS the ffmpegx place.
I will try the program you mention though. I'm just exhausted because I've tried 6 different programs already. Arg.
If all you need is .mp3 output, then may I suggest this application: All2MP3.
(It is also build around ffmpeg, but uses newer binaries.)
All2MP3 is a one trick pony, but easy as pie.
Not all FLV files are alike. FLV is a container (and sometimes even just a different kind of movie file with a renamed suffix), that can contain a variety of video codecs and audio codecs. Some of those codecs have lesser support by some conversion apps. Success with conversion does depend on which codecs were used, as proprietary codecs are sometimes discarded in open source software. YMMV.
Due to converting from flv to mp3 ffmpeg runs out with error
By Maxroy in forum Video ConversionReplies: 3Last Post: 7th Oct 2010, 15:23 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?
By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 22:11 -
Converting FLV to 3GP --> FLV Unrecognized?
By SnakeGirl in forum ffmpegX general discussionReplies: 1Last Post: 21st Jan 2008, 22:33
