Anyone try the trial "Ideal Blu-ray Copy" program?
I have tried to get “Ideal Blu-ray Copy” to run on my Win7 system and it stop while trying to analyze the disc. The program needs to connect to their server to remove the protection, but it doesn’t connect. Anyone else running into the problem?
QB
I'll be the first to say it: you're wasting your time.
There are a multitude of dubious blu-ray decryption programs, and it's well-known (here anyway), that most don't work. The ones that *do* work are in the Tools section here. If you don't see a decrypter listed in the tools section (and it's a short list), it's a rip-off.Pull! Bang! Darn! -
I had to configure your Kaspersky to allow Ideal Blu-ray Copy to work.
http://www.idealdvdcopy.com/bb/phpBB3/viewtopic.php?f=5&t=5635
It took an hour to rip, but it seems to require 50GB blanks; that is not going to happen too costly.
Update:
The program has real promise. I was just told Ver 1, does not have compression, but Ver 2 will. I would wait for Ver. 2.0.
QBLast edited by Quincyboy; 29th Apr 2011 at 08:47.
Blu Ray copy time
By pepegot1 in forum Blu-ray RippingReplies: 11Last Post: 17th May 2011, 17:21 -
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
Blu Ray With Digital Copy
By waheed in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2010, 20:58 -
Copy Blu Ray Movie Only
By cmjanus1 in forum Blu-ray RippingReplies: 9Last Post: 25th Jan 2009, 15:48 -
How do you copy blu-ray movies?
By JoeyGarbs in forum DVD RippingReplies: 9Last Post: 4th Sep 2007, 00:38
