I recently bought a laptop...my first one. I have only had desktops before. I will mainly be using this new laptop in my home office but went with the laptop to take on the road occationally. While using the laptop in my office,
Would it be better to take battery out and plug in to power all the time? and use battery when on the road?
Will this prolong the battery life?
Do I need to run battery down the recharge on regular basis?
Just wondering..... since I am new to the laptop scene.
Live Long and Prosper.![]()
Modern laptop lithium batteries will not overcharge if left on the power supply. In theory they will wear with the number of recharge cycles but when used as you describe, the batteries will probably give up from old age (approx 4-5 years) even if left on the shelf.
You should avoid fully discharging a lithium battery. There is no memory as found in NiCads.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
A couple of perspectives:
http://mobileoffice.about.com/od/usingyourlaptop/f/laptopbattery1.htm
http://mobileoffice.about.com/od/usingyourlaptop/f/laptopbattery.htm
Although I have no personal statistics to prove it, I feel like I've shortened the battery life of a couple laptops I've had by keeping them plugged in all the time with the batteries installed, so I remove the one for my netbook when I don't need portability. -
I bought a new Toshiba laptop a few months ago, and the manual says to NOT keep it plugged in all the time, and to fully discharge it once a month. Of course, that might be boilerplate from ten years ago, but it makes sense.
I had an HP laptop previously, and plugged in all the time, and when I took it off charge one time it died immediately, although the charge indicator said "Fully Charged". -
My laptop manual says not to let it charge for more than 8 hrs. or you can damage the battery. Of course it you are using it, that's okay, just don't leave it off and charging for more than 8 hrs.
I love children, girl children... about 16-40
W.C. Fields -
My Asus laptop does a good job of monitoring the battery. A orange battery light was flashing last month, and since it's a refurb laptop, I guessed the battery was dead. I unplugged the charger by accident and the LT ran till the battery was dead. Plugged it back in, no more orange light. Apparently the battery does need to be discharged at times. That's what the orange light was telling me.
That said, I keep my LTs plugged in all the time and the batteries die at about the same rate as batteries on the shelf.
And there used to be some laptops out there that wouldn't run without the battery installed. Probably a crappy power supply that would put too much voltage into the LT without the battery load to buffer it.
I would ask the question to the laptop manufacturer just to be on the safe side to keep from damaging either the LT or the battery.
Laptop battery sources
By ranchhand in forum ComputerReplies: 3Last Post: 4th Jan 2012, 06:56 -
Something wrong with my laptop battery
By aruwin in forum ComputerReplies: 4Last Post: 28th Sep 2011, 02:48 -
laptop + new battery = no Power
By nick101181 in forum ComputerReplies: 8Last Post: 15th Jan 2010, 13:29 -
Laptop replacement battery ?
By Noahtuck in forum ComputerReplies: 8Last Post: 10th Jan 2010, 12:54 -
laptop battery
By romanstopme in forum ComputerReplies: 7Last Post: 23rd Feb 2009, 03:03
