    Apr 2011
    Boulder Colorado
    Hello all,
    Wondering if anyone can tell me how best to reduce the bit rate on a video I spliced together. The video is 960x720 - codecs AAC and Video, duration of 10:44, 2 audio channels, 3.26 GB with a Bit Rate of 40,532... I need it down to less than 5000. I created the video from about 6 separate mpegs... it is currently a .mov file.
    Thanks in advance for any help!
    Ashley
    Convert two a mov or a mp4 with h264 video. Use mpeg streamclip or handbrake. You can adjust the bitrate in those apps and both works windows and macos.
    Apr 2011
    Boulder Colorado
    Thanks!
