I cannot use my camcorder with my new laptop computer as the firewire attachment that I used from the camera lead to the old computer does not fit the new computer.
The camcorder mordel is Canon MVX20i and the lead from that connected to the old computer via an Expresscard 34mm FireWire 1394a 2 ports.
My new laptop only has USB ports - no Firewire or PCMCIA slot.
When I have tried USB to USB, my laptop does not even see that there has been a device added.
My question is could I use a Firewire / USB adaptor in a USB socket on my laptop to plug my camera into the Firewire plug on the adaptor? Would I need additional software?
I know Pixela did a cable / adaptor for this a few years back but I cannot find one!
Any advice / solutions gratefully accepted.
The question comes up here on occasion: https://forum.videohelp.com/threads/333101-How-can-I-capture-video-with-no-firewire-port?
There is no easy solution. Best to get a tower computer and add a FireWire port. Even an older used PC with a PCI FW card would be a better solution than some sort of FW>USB adapter that most likely won't work with your camera.
http://www.kiva.org/about
Capturing DV camcorder to laptop w/o firewire port
By fvisagie in forum Capturing and VCRReplies: 33Last Post: 17th May 2012, 14:14 -
Sony HC3 firewire port dead,cheap miniDV camcorder to use for transfer?
By alegator in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 76Last Post: 13th Jul 2011, 20:59 -
Transfer AVI files from Laptop to Desktop via firewire?
By manhnt in forum Newbie / General discussionsReplies: 11Last Post: 1st Aug 2008, 15:51 -
How to connect VGA port on laptop to Svideo port on tv
By hulk420 in forum ComputerReplies: 4Last Post: 5th Jun 2008, 16:07 -
S Video Port on Laptop
By mblanco2000 in forum Media Center PC / MediaCentersReplies: 5Last Post: 24th Feb 2008, 17:10
