Hi,
I recently came across some sources that resulted in chroma issues when encoding using TFM().TDecimate() ivtc.
Looking at the TFM help file i managed to resolve these issues by using TFM(chroma = True), though the result of this was that the encoding process took longer.
I was wondering whether anyone knew any faster ways that chroma issues might be resolved?
Thanks in advance.
not sure ,sorry
are you saying TFM(chroma=true) resolves that issue ?? (chroma from a field is re-associated correctly) ? -
Yes, using TFM(Chroma = True) will resolve the issue and the picture becomes fine. However, as with many things with encoding/video conversion there are often several different possible solutions to the same problem, some better/faster than others. This thread was created to discover whether there were faster/more efficient/practical ways of achieving the same solution.
you can modify some TFM parameters, look at the docs
e.g. slow =0 will reduce accuracy, but increase speed (might be good enough for matching your specific clip or might screw up some matches)
If you have perfect matching and no combed frames, then maybe PP=0 to disable post processing
You can also try posting at Doom9 for more suggestions
faster blu-ray to dvd single layer conversion
By Steve(MS) in forum Blu-ray RippingReplies: 11Last Post: 10th Aug 2011, 21:02 -
Is there a faster way of converting MKV to mpeg2 for DVD than FAVC?
By Onceler2 in forum Video ConversionReplies: 1Last Post: 31st Jul 2011, 16:55 -
Chroma/Color Bleed Issues In MPEG2-->XviD Conversion
By onesikgypo in forum Video ConversionReplies: 8Last Post: 25th Jun 2011, 21:11 -
How to reduce bitrate of Xvid without recompressing or faster than this?
By dzsoul in forum Video ConversionReplies: 2Last Post: 18th Jan 2010, 05:59 -
Newbie stuck @ mpeg2 > xvid conversion
By kamaleon in forum Video ConversionReplies: 29Last Post: 29th Jan 2008, 17:45
