I feel like an idiot, but I can't get RipBot to extract to any file without errors on all the files. I've tried using WinRar and WinZip, and neither one will extract the download without errors. After extracting to a file, when I try to execute the RipBot.exe, I get an error that says it's not a valid Windows 32-bit executable file.
Results 1 to 9 of 9
Dan_Joyner,
Use 7-Zip: http://sourceforge.net/projects/sevenzip/files/7-ZipLast edited by jandor2009; 27th Apr 2011 at 13:10.
Uninstall the 7-Zip 9.22 current version...
Install the 7-Zip 9.20 previous version: http://sourceforge.net/projects/sevenzip/files/7-Zip/9.20/7z920.exe/downloadLast edited by jandor2009; 27th Apr 2011 at 13:07.
Just had quick look, I used RipBot but didn't like its lack of control, and for something that's supposed to be simple and straight forward to use, it uses and awful lot of external software. Avisynth can cause a lot of aggrevation for users as its a very very powerful piece of software on its own but not easy to get to grips with if you start getting problems
It did mention on the RipBot website that Windows XP users MUST install Windows Media Player 11
What exactly are you trying to achieve using RipBot, converting media to smaller files or putting movies onto something like an iPad or Android Pad/Phone ???
As suggested, have a look at another encoder and see if that fits your need. There are plenty of other 100% FREE encoders. I've tried quite a few and settled on VidCoder for ease of use but teh ability to change things when/if I wish
It's easy to use with the default settings without confusing you, can encode pretty much everything and has the ability to fiddle with settings to squeeze a bit more out of it or create your own profiles -
Uninstall all codec packs, AviSynth, Haali Media Splitter, ffdshow. XP users also must install Windows Media Player 11!
This is the basics for those who need to work with videos.
The RipBot264 is portable and already have their own tools.
The RipBot264 at least shows you what you need, while others install software and tools automatically.Last edited by jandor2009; 16th Apr 2013 at 06:25.
HELP!! Problem installing Ripbot 264
By livluvlife in forum Blu-ray RippingReplies: 11Last Post: 18th Feb 2015, 00:44 -
problems installing bd rebuilder
By davechubb in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2012, 03:09 -
Problems installing AIW drivers
By Ddanrr in forum Capturing and VCRReplies: 3Last Post: 10th Oct 2007, 20:14 -
Codec problems after installing k-lite
By woolf-gang in forum Software PlayingReplies: 9Last Post: 28th Sep 2007, 08:56 -
problems installing flash player
By stretchweider in forum MacReplies: 3Last Post: 29th Aug 2007, 09:51
