  1. Subtitle Workshop used to run properly, but there's now a problem: I cannot 'jump' to a subtitle either by double clicking it, or by dragging the cursor on the play bar. I did go to options and changed the settings to jjump to subtitle when double clicked, but to no avail. Why is this happening ?
  2. DECEASED
    Jun 2009
    Heaven
    Missing details:
    1) version of SW you're using
    2) version of Windows you're using
    3) whether you have installed some cräpwäre lately
    The less you say, the less your work gets done.
  3. I've got the same problem.
    Windows 7, Subtitle Workshop ver. 2.51. Anyone help?
