Hi all, i'm a newbie and i'm trying to convert a file DivX in an Mpeg2
The result is excellent for me but i have this problem:
the output file is 1.9GB then i need to cut it in two pieces...
I read all the info on the site and try all the programs, but i have always the same problem, the second part of the movie is out of synch....
What can i do? I try to synch it reading the info here and d/l all the software around but i can't make a good job!
Why my avi2mpg2 give me an error and i cannot use it?
Please help me!
Thx in advance!
(sorry for my bad english, I hope is clear)
What program did you use to convert the DivX to MPEG and was the entire movie in sync after the conversion?
If the entire movie was in sync and the sync problems resulted only from the process of spliting it into parts, I suggest trying TMPGenc's tools to split your MPEG file into parts. -
I used tmpGenc to convert it but the same program give me an error when i try to cut it...
Opssss sorry, i forget to reply you abt the Mpg file!
Yes it's perfect after conversion then i really don't know how to do...
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Batch convert ISO to AVI/Divx/MPEG
By extrememc in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2010, 18:13 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Command line method to convert MPEG-2 to Divx Home Theater Profile
By CLIjunkie in forum Video ConversionReplies: 15Last Post: 6th May 2008, 21:22 -
How to Convert 1280*720 DivX to a less dimensions DivX
By firas_hashim in forum Video ConversionReplies: 9Last Post: 27th Jun 2007, 08:33
